LabWindows/CVI
How can I report an active line number?
I've seen this used before, so I know it is possible. When I have a code failure I would like to be able to report an error trace to the operator, which includes the current line of code where the error occured. How can I obtain the current line number for code executing in CVI?
(3,296 Views)
Your looking for the __LINE__ macro.  there is also a __FILE__ and __FUNCTION__
(3,292 Views)
It works. Thanks.
(3,280 Views)
With regard to error reporting, here you can find some personal tips.
Also, take a look at this post that discusses the use of __FUNCTION__ macro in CVI8.5
(3,233 Views)
