LabWindows/CVI
How can I start LabWindows/CVI from a command line and pass it the name of file to be edited?
I am writing a coding standard inspection tool in Microsoft Develper Studio C#. In certain cases I want to instantiate and edit session of a CVI C source file. I need to know how to start LabWindows/CVI from the command line and pass an argument that is the file name to be edited. I have not found any discussion of starting LabWindows/CVI from a command line, nor in various reference manuals I have searched.
I know how to start something from the command line.
I know how to do what is required in C#. For example with NotePad.exe the following works:
Process.Start( "notepad.exe", "\"" + strFullPathname + "\"" );
 I don't have information on the LabWindows CVI command line.
I appreciate any useful response that may be offered.
(4,807 Views)
may be this helps: http://zone.ni.com/devzone/cda/epd/p/id/785
oops, afte reading your post the second time I realized that this was nto the answer... sorry
Message Edited by Wolfgang on 06-16-2010 03:05 PM
(4,805 Views)
OK, I'll try again: I have just tried to start CVI with a certain project from the command line, and it works! My example:
"C:\Program Files\National Instruments\CVI2009\cvi.exe" "C:\Documents and Settings\Wolfgang\My Documents\Fit\Fit.cws"
(4,800 Views)
Thanks Wolfgang. I suspected it to be very much like what you have purported. I am currently working from home. I will try your solution once I arrive at work. I was not sure of the exe file name, so it has definitely cleared that up. The next question is will it open just a source file instead of a whole project. I'll let you know later today. Allyn
(4,797 Views)
It opens the complete project, with the specified file type (uir, h, c) being the top most tab.
(4,793 Views)
For my situation the following C# code does the job:
    Process.Start(
       @"c:\Program Files\National Instruments\CVI71\cvi.exe",
       @"c:\temp\experiment.c" );
The file must already exist.
(4,780 Views)
well, actually it depends on the history: if the last time CVI was open, it contained three files, it will re-open these three files; hence in order to have only one tab/file opened one needs to close all the files before closing CVI.
(4,775 Views)
