LabWindows/CVI
How can I tell if an executable is already running?
I'm writing a rather large LabWindows/CVI program, and occasionally will triple-click on the desktop icon, starting two copies of it. Is there some way to tell if a program is already running, so that the second copy can shut itself off?
(3,866 Views)
Accepted by topic author pblase
Look at CheckForDuplicateAppInstance () command: the help page shows also a short programming example.
(3,862 Views)
Or if you want to do it another way create a named mutex that the application grabs when it starts, that way if it can't grab the named mutex you know that another instance of the application is already running.
(3,837 Views)
Ok, thanks much. I thought I remembered something being in there somewhere.
(3,829 Views)
> running.
Yet another way is to open a resource exclusively.
For instance with:
open(Filename, O_CREAT | O_EXLC | O_TEMPORARY)
The 2nd one will fail the call
Guillaume Dargaud
http://www.gdargaud.net/
(3,805 Views)
Speaking of using a resource, I used a named pipe to solve this problem in grad school once.  Prof thought it was weird but he couldn't deny that it does work Smiley Wink
(3,804 Views)
