LabWindows/CVI
How can I transfer a XML file content to a MS SQL database by stored procedure using LabWindows/CVI SQL Toolkit?
I have a problem to transfer a XML file content to a MS SQL database by a given/fixed stored procedure. I'm able to transfer the content of the file by using following method ...
hstmt = DBPrepareSQL (hdbc, EXEC usp_InsertReport '<Report> ..... </Report>');
resCode = DBExecutePreparedSQL (hstmt);
resCode = DBClosePreparedSQL (hstmt);
... but in this case I'm not able to fetch the return value of the stored procedure!
I have tried to follow the example of the stored procedure in the help documentation (DBPrepareSQL) but I miss a datatype for xml?!?
Any idea how to solve my problem?
KR Cake
(3,727 Views)
After some additional trials I found a solution by calling the stored procedure in this way
DBSetAttributeDefault (hdbc, ATTR_DB_COMMAND_TYPE, DB_COMMAND_STORED_PROC);
DBPrepareSQL (hdbc, "usp_InsertReport");
DBCreateParamInt (hstmt, "", DB_PARAM_RETURN_VALUE, -1);
DBCreateParamChar (hstmt, "XMLCONTENT", DB_PARAM_INPUT, sz_Buffer, (int) strlen(sz_Buffer) + 1 );
DBGetParamInt (hstmt, 1, &s32_TestId);
where sz_Buffer is my xml file content and s32_TestID the return value of the stored procdure (usp_InsertReport(@XMLCONTENT XML))
Now I face the problem, that DBCreateParamChar limits the buffer size to 8000 Bytes.
Any idea to by-pass this shortage??
(3,704 Views)
Hi Cake,
I think you should split up the file content then and transfer it to the database
in multiple steps.
Regards
DianaS
(3,651 Views)
Accepted by topic author Cake
Hi DianaS,
Thanks for your input. Meanwhile I found another way which fullfill my requirements:
resCode = DBSetAttributeDefault (hdbc, ATTR_DB_COMMAND_TYPE, DB_COMMAND_TEXT);
sprintf(sz_SqlStatement, "DECLARE @TESTID INT EXEC @TESTID = usp_InsertReport '%s' SELECT 'RetVal' = @TESTID", sz_Buffer);
hstmt = DBActivateSQL (hdbc, sz_SqlStatement);
 while ((resCode = DBFetchNext (hstmt)) == DB_SUCCESS)
   /* Get values into the record. */
   resCode = DBGetColInt (hstmt, 1, &s32_TestId);
 resCode = DBDeactivateSQL (hstmt);
sz_Buffer is the XML file content!
KR Cake
(3,630 Views)
