LabWindows/CVI
How can I transfer the binary data of an image to a Bitmap?
A certain part of my project consists in retreiving an image from a remote machine, which I am doing over TCP using HTTP GET method. The problem is that once I have retreived all the image bits in a char array, I don't know how to transfer it to a Bitmap. The only method I can think of is to create a file with the binary data, and then use GetBitmapFromFile. Is this the only possible way?
P.S. The image is a jpeg, if that's important.
Message Edited by bodisan on 03-13-2009 09:26 AM
(3,874 Views)
If you already have the image bits in an array, you can use the NewBitmap function to create a bitmap object. You don't have to write it to a file first.
Luis
(3,861 Views)
I think I used the wrong words... the http server is not sending me the image bits, it sends the binary data of the jpeg. As I understand it, the image bits are not the same with the jpeg data. The image bits are a plain description of each pixel, and the jpeg data contains a header, and the compressed information about the pixels.
(3,854 Views)
If it is the case that you are transferring actual jpg file bytes, then you should just be able to do something like the following:
FILE * jpgFile;
jpgFile = fopen("c:\\myfile.jpg", "wb");// write a binary file
fwrite(jpgDataBuf, /*size of the buffer */, /*num elements*/, jpgFile);
fclose(jpgFile);
NickB
(3,849 Views)
additionally, you may use a library for decoding the jpeg image in memory.
the first such library that comes to my mind is libjpeg which has a windows precompiled binary package here. download the package, include the .lib, and .h, read the doc, and do not forget to put the .dll along with your .exe.
i am pretty sure you can find a lot of similar libraries on the web.
(3,832 Views)
