LabWindows/CVI
How can I trigger 5411 arb from 6070E DAQ?
I have tried connecting both devices to the RTSI bus, but cannot seem to get it to work.
(2,877 Views)
The bus connections do not actually get made until you start an acquisition on the 6070E. If you are trying to trigger an instrument before an acquisition is initiated, then it will not work. One solution is to create a dummy acquistion when setting up the trigger.
(2,877 Views)
