LabWindows/CVI
How can I use ADO to connect database。
I am using LabWindows/CVI 6.0 to connect with SQL Server database.I have not the LabWindows/CVI SQL Toolkit .I wonder if I can use ADO to connect to database and execute select ?If so,what shall I DO?Can you give me an example about this.Best wish ,thanks!
(3,632 Views)
Ying Wei,
You can do this by creating an Active X server. I have attached a PDF document that thoroughly discusses how to do this.
Here is a post that also addresses this issue: �ADO and LabWindows/CVI�.
If you have any other questions please post back!
Craig H.
(3,632 Views)
Craig H.
Thank you very much.I have been searching this for a long time.Thanks for your help!
(3,632 Views)
Craig H.
I have had a overview on the ActiveX after looking through the PDF file.But when I decided to code my programme,I can not find a concret help in the file. I wonder if you can give me a more concret file or coding example.Appreciate your help.
By the way,you can communicate me with Email:weiyingjlu@yahoo.com.cn.
Thanks!
(3,632 Views)
