LabWindows/CVI
How can I write and use a function() with unknown parameters (... = ellipse)?
As I know function prototype for ellipse functiones are e.g. f(int count, long summ, ...).
But I do not know how to get the unknown count of parameter inside my function.
Regards
(3,550 Views)
Forelle,
I'm not sure I understand your question. Are you talking about how to return information from functions in C?
If so then this might help.
To return one value from a function do the following:
//Function Prototype
double f(long, double);
//Function call
value = f(count,summ);
//Function description
f(count,summ)
double amount=0.0;
amount = count * summ;
return amount;
To manipulate variables inside the function you need to use pointers. You can use references also I guess. Anyway, you could try something similar to what's in the included .txt file.
Grant
Grant M. Johnson
Project Engineer
LECO Corporation
(3,550 Views)
I suppose you're talking about functions that accept a variable list of arguments. If it's so, here you will find some useful hints and reference.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000EB2C0000&UCATEGORY_0=_46_%24_7_&UCATEGORY_S=0&USEARCHCONTEXT_TIER_0=0&USEARCHCONTEXT_TIER_S=0&USEARCHCONTEXT_QUESTION_0=variable+argument+list&USEARCHCONTEXT_QUESTION_S=0&RSESSION=101_4276:d4047b94005dc94a80a249ad:999597130962
Roberto
(3,550 Views)
I am sorry that I took you on the wrong path. I was talking about functions that accept a variable list of arguments.
See Roberto Bozzolos answer. He gave me a verry good hint.
Sincerely Forelle
(3,550 Views)
