LabWindows/CVI
How can call a dll made in c# 2008 in CVI
Hi
To all
I have a questions for you, I have a dll made in C# 2008 Express and I want to know if is possible to use  this dll in a program developed in CVI 6.0, I only have the file .dll, I do not have the header file .h and the file .lib because C# only generate the .dll file in the build.
I do not know if is possible to do this.
Can someone help me with this doubt??
Thanks in advanced for your support.
(3,579 Views)
did you check here?
(3,566 Views)
Hello
Wolfgang
Thanks for your responce but I have read the document before and I only see one conditions when the dll was made in visual C++ , The compilator C# has diferents things and in this document I do not see some instruccions when the dll was created in C#.
Do you have other idea or other link in where I can see something about this??
Thanks a lot.
(3,552 Views)
Well, I am not familiar with C# but I assume that you will need to declare the exported functions as extern C. In CVI then use the Windows SDK functions LoadLibrary and GetProcAddress as explained here.
(3,549 Views)
Hello
wolfgang.
I have try of do this that you mentioned below , but not work , because when I try to declare how .C the function declare in C# the compilador send me a error, In fact this is not valid in C#.
I thing that the CVI compilator can not to call a dll development in C# . I only need to confirm this.
Regards.
(3,493 Views)
