LabWindows/CVI
How can change one VI?
I need to correct the Bug in VI MB Modbus Command to Data Unit.
But, i don't have permission to edit this VI.
How can i do this?
(2,982 Views)
If the VI diagram is protected there is no way of accessing it unless you ask the permission to the owner. In any case, since your question is related to LabVIEW you should post it in the appropriate forum, where you can find better help on this subject.
(2,970 Views)
