LabWindows/CVI
How can i access a function inside a dll?
I' trying to access a dll's function but i can't. I have the header, dll and the type library. The function is declared as
short int __far DLLEXPORT DLLSTDCALL Download_Can( char *FileDescription, short int port_num, short int slot_num );
When i try to make my own lib i get an error in the DLLSTDCALL tag. Why is this...do i need to make a special consideration? I just need no add the .lib to my project in order to get access to the function in the dll, or i need something else? When i do this, i get a link error that says that the function i'm triying to access was not found.
(3,289 Views)
Seeing as you know the definition, but don?t have the header, you can declare a typedef as shown below:
typedef int (__stdcall *fnPtr)( char *FileDescription, short int port_num, short int slot_num);
You will then need to load the DLL using :
hRef=LoadLibrary(?Your DLL Name?);
After loading, you now need to get the address of the function you want to call:
nameFn=(fnPtr)GetProcAddress(hRef,"Download_Can");
And to call it, you use:
nameFn (FileDescription, port_num, slot_num);
All of those functions above are from the Windows SDK, so if you need any info on them, do a search using the function names.
If you need anymore help, ask away
Regards
Chris
(3,288 Views)
Oops..Slight error, you may have to change the typedef to use short int, and not int. Have a play and see what you find out.
Chris
(3,288 Views)
