LabWindows/CVI
How can you load data from an ethernet connection into a data table and then plot these values on a graph?
I am using an ethernet connection to obtain several data values and am then trying to gather these values and insert them into a table on cvi.
1) How should I go about setting up the ethernet connection with the CVI (I know the VISA library contains most of the functions for this, but any specific hints are appreciated).
2) Once the connection is set up, and the data values are being delievered back to the CVI, how do I put the values into a data table (there are lots of values being gathered).
Matt N.
neemtt
(2,914 Views)
Hi Matt,
CVI actually ships with many Internet and graphing examples.
I suggest you take a peek at the Internet examples in:
- C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\internet
- C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\tcp
- C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\udp
You may find graphing examples in:
C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\userint\graphs.cws
You may find table examples in:
C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\userint\colview.cws
C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\userint\databinding.cws
C:\Documents and Settings\All Users\Documents\National Instruments\CVI85\samples\userint\gridview.cws
Nestor
(2,891 Views)
