LabWindows/CVI
How do I Programmatically include files in the CVI Project window?
I would like to dynamically add and remove files from the CVI Project window.
How can I do this?
Thanks in advance.
Rajev.
(3,101 Views)
Hello
CVI provides an activex interface that you can use to control it programatically. Check out the example under ..\CVI\samples\activex\cvi. The project uses a CVI Activex Automation Server instrument. I believe the function you need is CVI_AppAddFileToProject().
Bilal Durrani
NI
Bilal Durrani
NI
(3,101 Views)
