LabWindows/CVI
How do I access VB.Net DLLs from CVI 6.0
Iam trying to access a VB.Net DLL from CVI version 6.0 but Im having no success. Does anybody have any suggestions or sample code ?
Thanks in advance
Kev
(3,203 Views)
CVI 8.0 has a 'Create .NET Controller' tool that can be used to create C wrappers to call .NET modules. If you do not have CVI 8.0, one possible solution is to create an ActiveX  (COM) wrapper for your .NET module using Microsoft tools like regasm and then use the CVI 'Create ActiveX Controller' tool to generate C wrappers to call via ActiveX. The following MSDN article has more information about createing COM wrappers (CCW) for .NET modules:
http://msdn.microsoft.com/netframework/programming/interop/default.aspx?pull=/library/en-us/dndotnet...
(3,184 Views)
Thanks , I had a look at this over the weekend and it looks like that will do the trick :smiley very-happy:
I managed to write a CCW'd DLL file and I will try using it in CVI today .
Kev
(3,157 Views)
