08-13-2003 11:34 AM
08-14-2003
11:23 AM
- last edited on
09-18-2026
09:43 AM
by
Content Cleaner
Hello Ning -
When using the TS_PropertyGetProperty(... TS_PropertyTypeVersion ...) you should see an error akin to "-17309," telling you that this particular property will only exist for property objects that are retrieved from 'type' objects in TestStand.
What this means is, that TypeVersion would be valid for objects of NI_NumericLimitTest or the like. It is not meant to be used with sequence files. You could also use this property when trying to manipulate datatypes.
When working with sequence files to retrieve the version information in TestStand 2.0.x you must use the TS_PropertyGetValString(thisContext...) and the lookup string mentioned in this earlier forum posting.
I hope this helps.
Elaine R.
http://www.ni.com/support
08-14-2003 03:39 PM
