Hello
If you have the ability to edit the UIR file, you can change the control label to exclude the "__" (double underscores that would prefix the name . So for a control labeled as __File, delete the underscores from the front of the name. Also, you can set the Shortcut key property of the control to assign it's Modifier Key to "None" and Key setting as " No Shortcut Key".
If you also want to disable the control so that the user cannot use tab to get to it, change its control mode to "Indicator". Indicators are not in the tab order. If you need Hot controls that are not in the tab order you will have to code it yourself using the EVENT_GOT_FOCUS.
I hope this helps
Bilal Durrani
NI
	Bilal Durrani
NI
