LabWindows/CVI
How do I generate a continous square signal (50% and 5V 50Khz) with GPCTR0 channel on a DAQ E series
Dear All,
I want to generate a square wave (50% ,5V 50Khz) with GPCTR0 channel by tradition DAQ function on the DAQ E series.
My DAQ Cards is 6070E, software is Labwindows7.1.
I first time to use GPCTR function, so I study the help and some samples on the internet.
But I also don't know how to generate my squre wave, Who can help me to make the sample program for me?
 GPCTR_Control(iDevice, ND_COUNTER_0, ND_RESET);
 Select_Signal (iDevice, ND_GPCTR0_OUTPUT, ND_GPCTR0_OUTPUT, ND_LOW_TO_HIGH);
Thanks very much for your help.
Joseph.
(3,169 Views)
Here some instructions taken from an application of mine:
                daqChk (GPCTR_Control (2, ND_COUNTER_0, ND_RESET));
                daqChk (GPCTR_Set_Application(2, ND_COUNTER_0, ND_PULSE_TRAIN_GNR));
                daqChk (GPCTR_Change_Parameter (2, ND_COUNTER_0, ND_SOURCE, ND_INTERNAL_20_MHZ));
                daqChk (GPCTR_Change_Parameter(2, ND_COUNTER_0, ND_COUNT_1, (unsigned long)val));
                daqChk (GPCTR_Change_Parameter(2, ND_COUNTER_0, ND_COUNT_2, (unsigned long)val));
                daqChk (Select_Signal (2, ND_GPCTR0_OUTPUT, ND_GPCTR0_OUTPUT, ND_LOW_TO_HIGH));
                daqChk (GPCTR_Control (2, ND_COUNTER_0, ND_PROGRAM));
It'been a long time since I wrote them, but as far as I remember the value of 'val' with respect to the source frequency defines the resulting frequency of the generated signal; that is:
The counter uses a base frequency (ND_INTERNAL_20_MHZ in my example)
Its output stays high for ND_COUNT_1 counts and low for ND_COUNT_2 counts; since I am passing the same value for those values the duty cycle will be 50%
Pulse train frequency is given by ND_INTERNAL_20_MHZ / (ND_COUNT_1 + ND_COUNT_2)
To obtain your 50 kHz frequency given the internal 20 MHz base frequency you should pass 200 as both count 1 and 2. If you use a different base frequency you must change those values accordingly.
You can download this example that shows a complete application for pulse train generation: it should be applicable to your hardware too.
Message Edited by Roberto Bozzolo on 11-26-2009 09:26 AM
(3,165 Views)
