LabWindows/CVI
How do I get CVI to generate symbol table and memory map files?
I want to know where my global variables and code are being placed in memory. More specifically, I want to know how much memory is required for my variables. CVI does not appear to allocate memory consecutively, so defining variables at start and end doesn't yield an answer.
(3,921 Views)
If you have CVI 7.0, you can get a memory map of your code if you check the Generate Map File option in the Build>>Target Settings dialog.
Luis
NI
(3,921 Views)
Thanks. That works. Next, is there a way to ensure that a set of variables is contiguous and consecqutive?
(3,921 Views)
I'm sorry but no, there isn't. I would have expected all the globals to be allocated consecutively, but if they're not, I know of no way that would make them be consecutive.
- luis
(3,921 Views)
Just for the record.
If you are using previous version of CVI, you can port your code to another compiler and generate the make file there.
Juan Carlos
(3,921 Views)
What about the ugly crutch of using a struct for all the globals and defining the globals
themselves as pointers to elements of the struct...? Yeah, I said 'ugly' !
Guillaume Dargaud
http://www.gdargaud.net/
"Maintenance Contractors always dress up nice, with a tie and everything because they believe
that a customer will trust a nicely dressed guy with their million dollar equipment just because
he's got a nice tie..." - Simon Travaglia (the B.O.F.H.).
(3,921 Views)
