I want to overlay a closed contour on the perimeter of the particle found by the function " imaqMeasureParticle." I need to have the information of the points in the perimeter of the particular particle for using the function "imaqOverlayClosedContour." I try to find a function for me to collect the information of points for me because you can find out the perimeter of the particle by the function " imaqMeasureParticle." So, I am supposed that there were a function to get the points info to calculate the perimeter. However, I cannot find it. Thus, I want to know that if there is any function I can use directly. Thank you in advance.
