LabWindows/CVI
How do I include Win32 API function, BitBlt(), in CVI7.0
Would someone please help,
I have two canvases on a PANEL: They are SOURCECANVAS and DESTCANVAS. I would like to copy a picture from SOURCECANVAS to DESTCANVAS
using Win32 API function  BitBlt()  in my CVI 7.0 code. (NOTE: I need to use this Win32 API function). From MSDN, BitBlt() function has the following form:
Bool BitBlt (HDC hdcDest,
                  int    nXDest,
                  int    nYDest,
                  int    nWidth,
                  int    nHeight,
                  HDC Src,
                  int    nXSrc,
                  int    nYSrc,
                  DWORD dwRop);
My question is  "how do I use CVI to obtain the destination Device Context handle (hdcDest), and also the source Device Context handle (Src)?"
A sample code would be appreciated.
Thanks in advance.
Bob
(4,167 Views)
Hello Robert,
My suggestion would be to use the following example which step through how to use that function in a .NET language, then use the Win32 to .NET function map to see which function in the Win32 SDK needs to be called to simulate the same results.  For instance to get the first parameter of the BitBlt function, you could use the GetWindowDC() function.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(4,149 Views)
If you want to copy a picture, use GetCtrlBitmap() to grab the bitmap from the source canvas and then use CanvasDrawBitmap() to draw that bitmap to the destination canvas.
Hope  this helps
Bilal Durrani
NI
(4,134 Views)
