LabWindows/CVI
How do I include a BMP with the Application in LabView
I have a VI that I would like to build into an application (.EXE).  The VI has a Picture indicator, whose source is a BMP on my local hard drive.  Using "Read BMP File.vi" and a Path constant, it's relatively easy to read the BMP and display it in the indicator.  I know how to include the file with the distribution (Build App or DLL -> Installer Settings -> Files), but how does one determine the location of the file after users install the EXE? I tried using just the filename of the picture in the path constant, hoping it would look in it's current directory, but I received an error.  With the full path in the path constant, everything works just fine.
Thank you,
...jerry
(3,039 Views)
JerryR,
try the attached VI for relative paths. sure you have to build another path on your own then.
i hope this helps,
Norbert B.
- NI Germany
Edit: place LV-question in the LabVIEW-department of this board in the future please.
Message Edited by Norbert B on 08-18-2005 10:04 AM
Norbert
Expert: Geometry
(3,013 Views)
