LabWindows/CVI
How do I include .cpp and associated .h file in LabWindows/CVI 7.0 project?
I would like to be able to use Visual C++ code written by someone else in my LabWindows/CVI project. Is there some way I can use or 'import' the .cpp and it's associated .h files rather than rewriting the the code from C++ to C? I've seen the discussions about importing C++ dll's, (use extern "C"{ }) does this also apply to .cpp's?
Peggy
(3,441 Views)
Hi Peggy,
You can just compile your .cpp to a DLL using Visual C++ and then call it from CVI. Other than rewriting it in C I don't know of any way to directly import a .cpp file.
Ryan K.
(3,441 Views)
