LabWindows/CVI
How do I integrate PuTTY in Labview?
Hi, the LabView serial port session VIs do not communicate well with my stepper motors (they do not respond to 50% of the stepper motor commands - Excitron stepper motors)   I want to create a VI that integrates the PuTTY serial port session manager into LabView so I can use PuTTY within LabView to control my motors.  Can someone help please?   I have found some mentioning of PIPES to do this but when I try to add it to my block diagram it says its unavailable - that source was from 2006 maybe there is another way now?
(4,323 Views)
you better ask this question in the LabVIEW forum here, this one is focused on LabWindows/CVI Smiley Wink
(4,322 Views)
Hi ErikaE,
I just want to agree with Wolfgang's advice to post this question in the LabVIEW forums. You will get the best advice possible from some of the most experienced LabVIEW programmers in the world there. Good luck with your issue!
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
(4,310 Views)
