LabWindows/CVI
How do I intercept a Close command?
I want to be able to intercept a Close message initiated by the user right-clicking my apps taskbar button and selecting Close from the resulting context menu. The button in question is the one that is created when a CVI executable first runs, i.e. not one directly associated with a CVI panel. I think it relates to something called a frame window which has a class name "CVIRTLVFrame4194304".
At the moment when the user does this, my app closes immediately without any the confirmation popups that I have chosen to present when other methods of exiting are used.
I think what I need to do is intercept the Windows message (WM_CLOSE ?) before it is handled by the default window procedure and route it to my own callback, rather than let the default windows procedure simply end the task.
Can anyone give me any guidance?
Jamie
(5,290 Views)
Maybe not entirely applicable to your actual problem, but this is a thread that presents various solutions about handling windows closing messages.
(5,280 Views)
Jamie,
You could try this:
  SetSystemAttribute (ATTR_TASKBAR_BUTTON_VISIBLE, 0);
Colin.
(5,276 Views)
Jamie,
You need to respond to the EVENT_END_TASK event that is sent to the main callback. Here's some example code that will never allow the Close command to do anything:
main()
    InstallMainCallback (maincb, 0, 0);
int CVICALLBACK maincb (int panelOrMenuBarHandle, int controlOrMenuItemID,
    int event, void *callbackData, int eventData1, int eventData2)
    if (event == EVENT_END_TASK)
        return 1;
    else
        return 0;
(5,252 Views)
Thanks to all of you. Much appreciated.
Jamie
(5,248 Views)
