LabWindows/CVI
How do I launch an executable?
I'm writing a serial client / server program that will remotely execute an application on the target system.  Only thing I'm missing is launching the exe from the code.  What library / functions can dynamically launch an exe given the path and filename?
Thanks!
(3,574 Views)
Hello -
Check out the documentation for LauchExecutable, LaunchExecutableEx, and system.  Between these functions, you should be able to find what you're looking for.
NickB
(3,572 Views)
