LabWindows/CVI
How do I parse strings into arrays
I am designing a Graphical User Interface in LabWindows CVI. I want to parse string from text box into array. For instance, if I get 1, 3, 5, 7, 9 in the text box, I want to create an array with elements 1, 3, 5, 7 and 9
(4,094 Views)
Once you have read the text box into a string, you can use two different methods to parse it:
1. If you know exactly how many items to scan, you can use Scan function with the appropriate specifier for the terminator character (as in your example, "%s[xt44]" terminates scanning on a comma)
2. If you don't know how many items to scan, you can use strtok function, scanning your string in a loop until its end (i.e. when strtok returns NULL)
Roberto
(4,094 Views)
