LabWindows/CVI
How do I pass a struct to a thread ?
I'm trying to pass a structure to a thread. I have trawled these forums for an answer and have found a few suggestions relating to scaler variables but not to structs. I have even tried substituting a struct in place of a var in the ThreadSafeVar example but to no avail.
If anyone can help here I would be really gratefull,
Thanks in advance for any feedback.
Message 1 of 8
(5,841 Views)
You can pass a structure to a thread by using a void *.
example:
typedef struct
    int a;
}MyStruct
ThreadFunc(void *)
     memcpy(
Message 2 of 8
(5,826 Views)
example:
typedef struct
    int a;
}MyStruct
ThreadFunc(void *)
     memcpy(
Message 3 of 8
(5,826 Views)
example:
typedef struct
    int a;
}MyStruct
ThreadFunc(void *)
     memcpy(
Message 4 of 8
(5,826 Views)
Sorry I hit tab and then the space bar and it posted.
example:
typedef struct
    int a;
}MyStruct
ThreadFunc(void *var)
     MyStruct tmp;
     memcpy(&tmp,  var, sizeof(MyStruct))
As an alternate to copy you can perform a type cast.
Message 5 of 8
(5,825 Views)
Thanks for your help.
My confusion stemmed from the NI documentation on variable protection which is a bit scatty to be honest. As I don't acually need to protect the struct at this moment in time then i've simply gone for:
static struct system testSystem;
CmtScheduleThreadPoolFunctionAdv (
                DEFAULT_THREAD_POOL_HANDLE,
                myFunction ,
                &testSystem,
                THREAD_PRIORITY_NORMAL,
                EnableInterface,
                EVENT_TP_THREAD_FUNCTION_END,
                0,
                RUN_IN_SCHEDULED_THREAD,
                &gThreadFunctionID);
Then pick it up in the function via:
int myFunction (void *functionData) {
    struct system* testSystem = functionData;
I believe this gives me a ref to the actual mem rather than having to make a copy of it.
Thanks.
Message Edited by steorn on 03-25-2008 11:00 AM
Message 6 of 8
(5,813 Views)
I know this thread is old, but I ran into an error and need a quick clarification.
I have this struct...
typedef struct
int id; //So we reference it correctly.  Issue may arise if we support instrument with different communication type (RS2323 or USB)
int funcID;  //Can derive which type of Instrument from funcID
} device_ref_table;
typedef struct{
 int id;
 int funcID;
} device_ref_table;
I want to do the following ThreadPoolFunctionCall and pass the struct as the pointer to void
device_ref_table drt;
CmtScheduleThreadPoolFunction(DEFAULT_THREAD_POOL_HANDLE,InstrumentFunctions,(void*)drt,NULL);
BUT, I get "Cast from 'device_ref_table' to 'pointer to void' is illegal
On the receiving end...
I have the following which may not be correct yet, since I keep changing it.
int CVICALLBACK InstrumentFunctions (void *functionData)
device_ref_table *drt = functionData;
I don't think I want to pass the address of the struct because if I make this same call twice with different values before the Callback function finishes, I believe I will have some issues.
If this can't be done, or if someone thinks its easier, should I pass a 2 variable integer array?
Thanks in Advance.
Nick
Message 7 of 8
(5,336 Views)
You must pass the address of the structure. As in:
    CmtScheduleThreadPoolFunction(DEFAULT_THREAD_POOL_HANDLE,InstrumentFunctions,(void*)&drt,NULL);
This is compatible with your receiving code.
JR
Message 8 of 8
(5,332 Views)
