LabWindows/CVI
How do I programmatically hide a folder (not a file) in windows using CVI?
In windows, there is CVI code to hide a file. What I want is a code to hide a folder. Is there a function like that in CVI?
Thank you.
Bob
(4,285 Views)
Can you use the window function:
SetFileAttributes(szDirName, FILE_ATTRIBUTE_HIDDEN);
(4,262 Views)
I have tried it. This only hides a file not a folder.
(4,235 Views)
It works on my machine:
You should see a file attribute named H.
Also select hidden files and folders in folder option setup.
(4,227 Views)
That works, but how do I programmatically do that in CVI?
Thanks for your response.
Bob
(4,206 Views)
I'm not sure there's a native CVI function that will accomplish this. It looks like most of the directory functions are in utility.h, which is where the function that can hide files lives. There doesn't seem to be a mirrored attribute setting function for directories, though. Have you looked into running a command line argument from CVI and hiding the folder that way?
Claire M.
Technical Support
Certified LabVIEW Developer
(4,170 Views)
According to MSDN, SetFileAttribute(dirName, FILE_ATTRIBUTE_HIDDEN); should work for both files and directories.
Obviously you should not change it like this but rather like this:
BOOL success = FALSE;
DWORD attr = GetFileAttribute(dirName);
if (attr != INVALID_FILE_ATTRIBUTES)
    attr |= FILE_ATTRIBUTE_HIDDEN;
    success = SetFileAttribute(dirName, attr);
Otherwise the SetFileAttribute() function will fail as you try to delete the FILE_ATTRIBUTE_DIRECTORY flag which this function can explicitly not be used for!!
To change the setting in the control panel how Explorer lists such directories is another story entirely. Generally an application should NOT force changes to a (user configurable) environment setting. If an application does, I consider it hostile and would quite likely deinstall it immediately.
Rolf Kalbermatter  My Blog
(4,166 Views)
