LabWindows/CVI
How do I remove files from the search list in CVI 7.1?
When searching for text in LabWindows/CVI 7.1 files, the search list contains several "old" versions of files that I don't really want to search or files that are irrelevant to the currently loaded project. Is there a way to remove files and/or directories from the search list?
(2,916 Views)
I'm assuming you're talking about the Find.. feature found under the Edit menu. If you just want to search the currently active file (frontmost window), then Multiple Files should be unchecked. If you want to search multiple files, but restrict the search to specific files, you have multiple files checked, but under Additional Files, you should Clear All check marks and only mark the files you want to search. Hope this helps! If this is not what you are referring to, can you give me some more detail about which feature you're trying to use? Thanks!
Jeremy L.
Jeremy L.
(2,917 Views)
