LabWindows/CVI
How do I send e-mail to a distribution list using LabWindows/CVI?
I need to be able to send e-mail to a user-defined distribution list using LabWindows/CVI? Has anyone done this? Any ideas where I could look?
Message 1 of 12
(6,225 Views)
The Enterprise Connectivity Toolkit contains the functionality to send emails with CVI:
http://sine.ni.com/apps/we/nioc.vp?cid=11128〈=US
Ryan K.
Message 2 of 12
(6,226 Views)
Ryan - Thanks for the tip. Got it working.
Sunil.
Message 3 of 12
(6,227 Views)
Hello
i get the error -7 when is send this mail with Labwindows CVI 9.0.1 .
 _tmp1 = InetSendMail ("smtp.gmail.com", "supersnowV7@gmail.com", "info@technofase.com", "Test Mail", "Prova", "");
I create the mail box with gMail but i can't send it.
I try to send the same mail with WINDOWS LIVE MAIL and i send it (so no problem by the Mail Server).
Can somebody help me ?
Regards
Message 4 of 12
(5,791 Views)
did you try the sendmail example provided with CVI? May be you should use '\0' in your file list if you are not going to attach files.
Message 5 of 12
(5,786 Views)
Hello
thank you but dosn't work. (also with /0)
I get always the -7 error back.
I dont understand wy.
Regards
Message 6 of 12
(5,779 Views)
Hello
someone can help me ? I can't send the mail from my  CVI project...
Thank'you.
Message 7 of 12
(5,698 Views)
Hi ,
Gmail outgoing mail server is using this settings : SSL enabled, via port 465 .
i don't know for sure but maybe u can check it..... see if this port is really open or something like that....
i hope it will help...
EDIT :
One more this u can use the pop3 functions......
Kobi Kalif
Software Engineer
Message 8 of 12
(5,688 Views)
I commented on something similar to this awhile back.  My issue was that I had the base version and didn't have the Internet classes.  So this external app worked like a charm 🙂
It has a lot of command-line inputer options to use as well.
http://forums.ni.com/t5/LabWindows-CVI/Need-Help-for-Sending-Email-with-LabWindows-8-5-or-9/m-p/1095...
Message 9 of 12
(5,609 Views)
Hello, please  help me, when I use InetSendMail ,I get always the -7 error  and I understand  the problem
Message 10 of 12
(5,049 Views)
