LabWindows/CVI
How do I send real numbers through rs232?
I know this should be easy but I can't figure out how to do it. I have a real number of type FLOAT (ex. 3.14) and I want to send it through the serial port via rs232. How do I convert this number into a character string that I can use as a parameter in ComWrt()?
Also, on the other end, how would I read it using ComRd(), and convert the character string back into a real number?
Thanks in advance.
(4,010 Views)
To convert from a double/float to say a string I tend to use the following:
#define OUTPUT_STRING "pwr=%f dBm\n"
sprintf (pszMyOutputString,OUTPUT_STRING,"45.56");
The string "pszMyOutputString" should now contain "pwr = 45.56 dBm\n" which you can send to your rs232
To convert from string to say float (or double in this case) you can use the strtod function.
*pdValue = strtod (pszTmp, NULL);
pdValue is a pointer to a double to contain the result.
pszTmp is a point to a null terminated string that contains the floating point number.
the NULL is this case is used to indentify the first character in pszTmp that I do not want to convert
(so if I had 3.14dBM), I would point the 'd' and not a NULL).
aDouble= strtod ("3.14", NULL
Hope this helps, if not, let me know and I can elaborate further,
Regards
Chris
(4,010 Views)
Thank you so much!!! That was a big help!
(4,010 Views)
No problem...
Chris
(4,010 Views)
Don't forget that if you READ a string from RS232, there is no terminating
null.
"Shiner" wrote in message
news:506500000005000000C4890000-1023576873000@exchange.ni.com...
> following:
> aDouble= strtod ("3.14", NULL);
> Regards
> Chris
(4,010 Views)
