LabWindows/CVI
How do I set the Debug LabVIEW.exe file path
I am debugging a older instrument driver using LabWindows CVI and when I try to Run Debug LabVIEW.exe, I get an error because the file path for LabVIEW 7.0 does not exist. I have a the most current version of LabView.
(3,541 Views)
Hello Joe,
I am curious if the older intstrument driver made any calls into LabVIEW.  Can you indicate whether or not this was the case?  Also, when you describe trying to "Run Debug LabVIEW.exe" are you conveying that you tried to step into LabVIEW for debugging purposes?  Can you clarify what you mean by this statement?  Thank you in advance for this additional information!
(3,511 Views)
