LabWindows/CVI
How do I single step into my LabWindows/CVI source code from TestStand
How do I single step into my LabWindows/CVI source code when I am running TestStand ?
(3,257 Views)
What you need to do is run teststand from CVI, and then any breakpoints you insert should be observed... to do this, select teststand as the extenal process in the 'select external process' item on the project run menu... When you run the project subsequently, teststand should be started, with access to the single stepping you require..
Regards
JB
(3,257 Views)
Thats spot on.
I'd really like to work with you someday, your knowledge on NI products is amazing...
How many sugars do you like in your coffee
Yours in awe 😉
(3,257 Views)
