11-21-2002 06:16 PM
11-22-2002
09:29 AM
- last edited on
06-26-2026
09:04 AM
by
Content Cleaner
Hello
Did you test out your program on the same machine, like doing a read and a write, just to see if all the parameters are correct?
Since you are using the SDK, you might want to make sure that you are using the functions correctly. At this time, CVI doesnt have any UDP functions, so you since you are using the Microsoft SDK functions, you want to make sure that you check the MSDN for example code and make sure all the parameters are set up correctly.
I hope this helps
Bilal Durrani
NI
