LabWindows/CVI
How do I use a .NET Control (RichTextBox) in LabWindows/CVI
How do I use a .NET Control (RichTextBox) in LabWindows/CVI (version 8.1)?
Specifically, I want to use a .NET control based on Windows.Forms.RichTextBox.
(4,293 Views)
Hi kcoggins,
Currently LabWindows/CVI doesn't support hosting .NET WinForm controls. We only have support for hosting ActiveX controls in our user interface.  We just haven't had enough interest from customers in this area yet. However, I would like you to submit a product suggestion so that we can keep track of the requested need.
Best Regards,
Message Edited by Jonathan N on 10-25-2007 12:49 PM
Jonathan N.
(4,275 Views)
You can use the activex rich text box. Check out the example in \samples\userint\activex\richTextbox.prj
http://forums.ni.com/ni/board/message?board.id=180&message.id=30947#M30947
- jared
(4,246 Views)
Hi kcoggins,
Just for our benefit, did you have a specific reason for wanting to use the .NET RichtextBox control? Did you know about the ActiveX version? Is your background mostly in .NET or C?
Best Regards,
Jonathan N.
(4,233 Views)
I did not do a thorough enough review to figure out that COM was available.  My background is .NET and C, however I have never used .NET or COM with LabWindows/CVI.  Thanks again for your assistance.
(4,202 Views)
I meant that I did not have experience with ActiveX and LabWindows/CVI.  I am using a Borland compiler with LabWindows/CVI, and Borland does not have the Rich Text support that I require for my application - this is why I was asking.
(4,201 Views)
