LabWindows/CVI
How do I use a windows function ( _itoa() ) in LabWindows/CVI?
The exact function is:
char *_itoa( int value, char *string, int radix );
(4,364 Views)
itoa is not an ANSI function; it's not a standard C function. Therefore, it is not supported by all compilers, unlike atoi.
You can use Fmt function in CVI. Please refer to LW/CVI Help file that ships with LW/CVI.
Mika Fukuchi
(4,364 Views)
_itoa() is specific to Microsoft VC++ and some other compilers, it is not a Windows API function. You can use the CVI Fmt() or standard C sprintf() functions instead.
Martin.
Martin
Certified CVI Developer
(4,364 Views)
Thank you very much! That is very helpful to know.
(4,364 Views)
Thank you!
(4,364 Views)
