LabWindows/CVI
How do I use global variables from one dll in another (not multi-threaded)
Using LabWindows/CVI. I'm trying to be compatible with legacy code, so this isn't the best way to do things but it saves me some headaches.
I have one project/.dll called "GlobalBlock" that contains certain parameters used widely throughout the program. The whole program consists of multiple dlls, for encapsulation purposes.
GlobalBlock.c contains:
struct menu_sdef G_setprefs =
//... stuff
struct sys_fileheader_sdef Level1Version =
//... more stuff
struct sys_flags_sdef G_sys_flags;
(3,512 Views)
Sorry, hit the wrong button.
GlobalBlock.h contains:
   #ifndef __GlobalBlock_C__
    extern struct menu_sdef              G_setprefs;
    extern struct sys_fileheader_sdef Level1Version;
    extern struct sys_flags_sdef        G_sys_flags;
   #endif
When I compile the second dll, Plots.c, the C code for which contains something like
   #include "GlobalBlock.h"
G_setprefs.X = 1.23;
I get :
"undefined symbol '_G_setprefs' in Plots.c
"undefined symbol '_G_sys_flags' in Plots.c
The Build option to include the .h file in the library is set.
I've searched the forums and the help files, and can't find any indication that I should be doing anything different.
(3,510 Views)
Accepted by topic author pblase
In the dll that owns the variable, use the _export qualifier on it. This will ensure that it is placed in the dll interface list. In the application (dll or otherwise) that wants to reference this variable, use the _import qualifier on it. This tells the system to use the associated import library that comes with the dll, in order to resolve the references at run time.
JR
(3,485 Views)
Thanks much.
Paul
(3,460 Views)
