LabWindows/CVI
How do i create a "tip strip" in LabWindows/CVI
I'm well aware of how easy it is to do it in LabView, but i can't seem to find any information on how to do it in Labwindows. There are other ways i can approach dropping hints, but I really like what the tip strips do for me.
(3,148 Views)
Accepted by topic author SPSUfridge
The equivalent in CVI is called "tooltip" and is set programmatically by SetCtrlToolTipAttribute () function: with CTRL_TOOLTIP_ATTR_ENABLE attribute you decide whether to display the tooltip or not, while with CTRL_TOOLTIP_ATTR_TEXT you set the text to display. Links are to CVI 2009 help. There are some caveats when using tooltips: here a case in which tooltips are inadvertedly switched off.
(3,146 Views)
