LabWindows/CVI
How do i refresh/redraw panel/window during a long time delay and switching between applications??
While waiting for delay to finish, and another application comes into focus, my application window is not refreshed when I select it.  All i get is a blank panel until the time delay is complete...
TIA.
(3,093 Views)
Hello TIA,
I assume you are using the Delay() function to do your time delay.  Instead, I would suggest using the Sleep() Windows SDK function, or implement your own delay function with a while loop and ProcessSystemEvents
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,089 Views)
delay function with a while loop and ProcessSystemEvents.  Worked, however the Sleep(); function did not (don't know if it is due to call of RunUserInterface();)
Thanks-
(3,086 Views)
