LabWindows/CVI
How do you append data to a text box using SetCtrlVal()?
The SetCtrlVal() function panel help says:
"When you call SetCtrlVal on a text box, SetCtrlVal appends value to the contents of the text box. Use ResetTextBox to replace the contents of the text box with value."
Everytime I use SetCtrlVal() it replaces the contents of the text box rather than appending as the help suggests.
Have I misinterpeted the help?
(6,577 Views)
You have correctly interpreted the help. It may happen that the new text entered moves old contents of the text box out of the viewable area, so that it seems that old text has been replaced. Try enlarging the text box or retrieving its value in a string and look at the string.
(6,577 Views)
Also, make sure you're using a text box and not a string. SetCtrlVal on a string replaces the string.
(6,577 Views)
Thanks, I see the problem now. "Box" is the key word in the help.
There are 3 kinds of Text Controls.
String, Text Label and Text Box.
The Append only works with the Text Box, I was trying to use a Text Label.
(6,577 Views)
If you need to do an append to a label, first call GetCtrlVal, then strcat your new data to append, then call SetCtrlVal.
(6,577 Views)
