LabWindows/CVI
How do you create an RGB color display using vision tools?
I am trying to use the IMAQ display functions to present some RGB color information.  The create image let's me create an RGB image but there doesn't seem to be a corresponding function to put data into it...you get options like 8bit, 16bit, and the like, but no RGB.
Thanks for the help.
Hummer 1
(3,159 Views)
Hummer,
Where are you acquiring your image from?  If it is from a file you will need to use the IMAQ ReadFile VI in order to bring in the data to your IMAQ Create.
Chris LS
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(3,130 Views)
I'm trying to generate a display from numbers...right now, I want to generate a flat screen with all the same color.  I asked this question on the vision forum (please excuse the extra post) and got the use the color fill function...and that works.
Thanks.
(3,116 Views)
