LabWindows/CVI
How do you fix the math errors when converting a string to a double?
Often an instrument will return a measurement through a communications device as an ASCII string. This requires conversion to a numeric value so that the measurement can be tested against numeric limits.
In this example if you were testing to a limit less than or equal to 58.7, the test would fail even though the measurement was passing.
Scan("58.7000", "%f", &number);
number = 58.700000000000003
(4,290 Views)
Dont know if there is a standard way of doing this or not. A real cheap and dirty way ive used in the past was something like:
number = ((int)number*100000)/100000
IE multiply the number to desired precision, convert to an integer to drop off the rounding errors, and divide back to get original answer. Sorry I dont have a better answer. I havnt had to use something like this in a very long time...
(4,274 Views)
Hi Concept,
You remember the values stored as floats and doubles are a little 'sloppy', right? So, think about how much precision the max number needs to have.
scan("58.7000", "%f", &number);
numPrecision = 0.000001;
if (number < (58.7 + numPrecision)) {
You can use the same concept to subtract from a min value and enforce a max-min range (or even a min range by itself).
if ((number < (58.7 + numPrecision)) && (number > (38.125 - numPrecision))) {
Orlan
(4,270 Views)
ScanFile (InputString, "%s>%f", &DoubleValue);
Is there not a modifier (or set of modifiers) either on the source string variable and/or the target double variable that will get rid of this problem?
My input char string is always something like -12.5000 or -9.3500 (always four digits after the decimal).
Sometimes it nails it with all zeros, and sometimes I get -12.500000000000001 or -9.350000000000001.
The code is a solution of course (and what I'm doing now), but not very elegant...
(3,814 Views)
Here's what I ended up with.
Value *= 10000;              // Turns the important part into a integer (up to 4 decimal places).
modf (Value, &Value);     // Gets rid of any remainder.
Value /= 10000;             // Turns Value back into the original number without the conversion error.
(3,791 Views)
