LabWindows/CVI
How do you turn on an LED based on an event in LabWindows/CVI?
I don't understand which function is used to control the state of the LED.
(4,073 Views)
//Turn on
SetCtrlVal(hPanel, hLedCtrl, 1);
//Turn off
SetCtrlVal(hPanel, hLedCtrl, 0);
(4,073 Views)
Thank you. I was getting a compile error in my .h file saying that SetCtrlVal was already declared. I didn't understand this until I looked into the userint.h file and saw it was already declared there.
(4,073 Views)
you're welcome.
One quick way to see if a function is a CVI one, is to first write only the name of the function, and while the cursor is on it press CTRL+P.
This will recall the function panel help if it is a cvi one, or it will tell you that it cannot recoginized the functions.
Best regards.
(4,073 Views)
