LabWindows/CVI
How does the function "AnalysisLibErrType Correlate (double arrayX[], int sizeX, double arrayY[], int sizeY, double outputArray[]);" work?
Dear all:
      When I use this function to find the correlation of two input arrays X[33112] and Y[16537], it will cost 4 seconds.
Then I try to write this function by myself using the formula:
yi = 0 when j < 0 or j m, xi = 0 when j < 0 or j n(supplied by NI Labwindows/CVI Help),
it will cost about 3 minutes. Could you tell me, with what method, Can I save the time as the Advanced Analysis Library function "Correlate"?
      Thanks!
帖子被尤文蒂尼在03-08-2006 08:46 PM时编辑过了
Message 1 of 1
(3,172 Views)
