LabWindows/CVI
How many lines of code in my program?
Is there a way to find out just how many lines your code has, preferable, the whole project or workspace.
(3,832 Views)
Hello Rafi,
There is a way to count the number of lines in a source file programmatically. You would use the NI LabWindows/CVI Server 7.0 instrument (Tools >> Create ActiveX Controller >> Next >> NI LabWindows/CVI Server 7.0).
This instrument will allow you to access functions to report on the CVI environment.
In particular, you would use the CVI_AppGetNumberOfLinesInFile (...). This function takes in an handle to a CVI application and a source file and returns the number of lines in the given source file. You would get the object handle for the current open CVI application by calling ActiveApp (...).
Thanks. I hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,817 Views)
Hi All,
Coming back to this super old thread to share an example code I created from the suggestion given above!
Attached is a CVI project of a simple command-line application that can list and count the number of lines of code of all Source Code Files in a given CVI project.
Here is an image exemplifying this application running.
I hope that helps!
Felipe Flores
Technical Support Engineer
(2,131 Views)
