LabWindows/CVI
How send menu shortcut keystroke from child to parent panel
One possible alternative could be ti use FakeKeystroke command, but is sends command to the active panel. which means you must activate the other panel, issue the command and then return to the original panel, with possible effects on screen.
Message 11 of 11
(1,340 Views)
