LabWindows/CVI
How set time x axis with PlotStripChar();
I use the command        PlotStripChart (panelHandle, PANEL_GRAPH,voltages, nbrchan, 0, 0,VAL_DOUBLE);
How can I have a time execution over the axe x. I fact, i would have a graph for 5 sec.
Help. (I have 8 channels for the acquisition)
(3,045 Views)
Since for a strip chart you can only set the number of points per screen, you can use SetCtrlAttribute() putting ATTR_POINTS_PER_SCREEN to the number of samples for the 5 secs acquisition.
Roberto
(3,045 Views)
