LabWindows/CVI
How to USE ComCallback ?
I need to get a SERIAL data when its available. But I don't know how to use and to init the COMCallBack.
Can you please write some sample code ?
thank you
(4,386 Views)
This excerpt is in the online CVI help and seems to be fairly clear...
EXAMPLE:
notifyCount = 50; /* Wait for at least 50 bytes in queue. */
eventChar = 13; /* Wait for LF. */
eventMask = LWRS_RXFLAG | LWRS_TXEMPTY | LWRS_RECEIVE;
InstallComCallback (comport, eventMask, notifyCount,
eventChar, ComCallback, NULL);
/* Callback Function */
void ComCallback(int portNo, int eventMask, void *data)
if (eventMask & LWRS_RXFLAG)
printf("Received specified character\n");
if (eventMask & LWRS_TXEMPTY)
printf("Transmit queue now empty\n");
if (eventMask & LWRS_RECEIVE)
printf("50 or more bytes in input queue\n");
(4,386 Views)
You can use the InstallComCallback function, which allows you to install a synchronous callback function for a particular COM port. The callback function is called whenever any of the events specified in eventMask occur on the COM port and you allow the system to process events.
Example:
Using the RS232 Library InstallComCallback Function to Handle Events
I hope it helps.
(4,386 Views)
Hello
I am using the comcallback function and it works well until I call a  function that needs information to be updated from the serial port com. When excuting that one "XModemRcvRoutine " the programme doesn't interrupt to receive information!!!
(the code is below and there is a copy of the project inthe attached file)
I wonder if there is someone who can help me.
Thank you in advance to any one whmay be able to give me some solution to my problem.
(3,390 Views)
