LabWindows/CVI
How to add dynamically added .obj or the lib files to the Labwindows/CVI test executive
I am using the Test Executive developed in Lab Windows/CVI. I have to add .obj file (Ex. XXXX.obj) or a lib file (Ex: XXXX.lib) file to the Test Executive dynamically. I should not add either the .obj or the lib file and then once again rebuild the test executive project and then run the exe. I have to add them dynamically with out rebuild every time.
(3,618 Views)
Hello MSR,
It seems like Test Executive did not have that functionality (dynamically load object and lib files without recompiling). Since Test Executive if no longer supported, I would suggest upgrading to its successor, TestStand. TestStand has more than 20 times as many features as the LabWindows/CVI test executive toolkit. However, TestStand's fundamental operation is quite similar to the CVI test executive toolkit.
Wendy L
LabWindows/CVI Developer Newsletter
(3,601 Views)
Hi all,
While (Condition)
 <Code>
 DAQmxReadAnalogF64 (AIN,1,10.0,DAQmx_Val_GroupByChannel, AnalogIn, 1, &NumberOfSamples,NULL)
 <Code>
 DAQmxReadDigitalLines (Handle, 1, 10.0, DAQmx_Val_GroupByChannel, &BitValue, 1, &NumberOfSamples, NULL, NULL)
 <Code>
 DAQmxWriteDigitalLines (handle, 1, 1, 10.0, DAQmx_Val_GroupByChannel, &BitValue, NULL,NULL)
 <Code>
 DAQmxWriteAnalogF64 (Handle,1,1,10.0,DAQmx_Val_GroupByChannel,&Voltage, NULL, NULL)
 <code>
All I need is to read only one sample value from the analog and digital In channels and write only one sample value to the analog
and digital out channels.
My application needs to while loop to execute around 1000 times per second. When I run the code I found my while loops executes
around 190 times/second only. (I takes around 6 millisec for one iteration of the while loop).
When i commented all the DAQmx function and hardcoded the values (for my calculations) my entire while loop executes very fast
and it executes around 1050 times/second. (around 0.9 millisec for one iteration of the while loop)
Then I uncommented the all the last three DAQmx functions ie., DAQmxReadDigitalLines, DAQmxWriteDigitalLines, DAQmxWriteAnalogF64
and when i executed the code the loop executed around 500 times/second (around 2 millisec for one iteration of the while loop)
When I uncommented the remaining function DAQmxReadAnalogF64 (The first one) once again the loop execution is around only
190 times/second.(around 6 millisec for one iteration of the while loop)
My question here is what is the execution time for the DAQmxReadAnalogF64. Why there is a big difference int the
execution timing just for the one read function.
Is there anything i can do to improve the execution time of the code.
When I analysed the DAQmx functions i found there is another function called as DAQmxReadRaw.
If I use this function for DAQmxReadAnalogF64 will there be any significant improvement in my exectution time.
I am kind of new to DAQmx drivers. Any help/suggestions would be of great use to me.
Sridhar
(3,439 Views)
Let's continue this discussion in your other post, found here.
Mark E.
Precision DC Product Support Engineer
(3,398 Views)
