LabWindows/CVI
How to add scroll bar to an active x document (PDF)?
Hello!
I have created an active x object (create from file) to view a pdf document directly in the main panel. But the problem is that my document is a multipage pdf document and i only view the first page of this doc.
So how can I do to view the other pages or how can i do to add a scroll  bar.
Thank you
(3,288 Views)
Hello rf31,
With the Acrobat reader, there is function called AcroPDFLib_IAcroAXDocShimgotoNextPage
Hope this helps. If it doesn't please provide me with more information about the way you use CVI to display PDF files into an UIR.
(3,257 Views)
